On a US English keyboard the colon is one key to the right of the letter L. The percent symbol is above the number 5 on the top row of the keyboard not the numeric keypad on the right side. If these keys do not work then your keyboard is bad.
Yes this is easy,to get the 'cent' symbol just hold down the 'AltGr' key with the '4' key and hey presto!! As for the other symbols you'll have to be a bit more clearer on your question ok!
In Excel 2003, place your cursor where you want the Philippine Peso sign to appear.
Select Insert > Symbol.
In the Symbol dialog box Symbols tab Subset dropdown list scroll to find and select Currency Symbols.
The capitol P with two horizontal lines through the top half should be visible one column to the right and one row down from the currently selected symbol or somewhere else nearby.
Select the symbol you want and select Insert > Close. The symbol will be where it should be.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Hi never ever disable nat on your router as that is the one which gives ip address to computer , x-box etc. You can make your x-box live work by just opening some ports
1. open rsp by typing in 192.168.2.1
2. On the left hand side under firewall you"ll find virtual servers
3. Click on that --- You"ll find some fields then check on enable for 1,2,3(ie three rows)
4.Description - x-box for all three
5.Inbound Port: 88-88 ,connection type : udp ,private port : 88-88 for the first row
6. Inbound port : 3074-3074 , connection type : udp , private port : 3074-3074 for second row
7. Inbound Port : 3074-3074 ,connection type : tcp , private port : 3074-3074
8. As FOR the private ip address it is that of your x-box which you can find on the dash board of your x-box . Same for all three rows .
9. Best of luck And do rate me
