The pump is blocked or the pump could be bad and need to be replaced.remove the bottom panel.if water is still in the tub,get a shop vac and vac out the water,then you'll see in the middle of the pump a piece that unscrews.turn it slowly counter clockwise,when the water starts to leak vac it up until it stops leaking and remove the middle piece out of the pump,clean out the catch,put the piece back in,add a little water to the machine and put it on drain,if it drains then you are done,if it doesn't you'll need a new pump.call your parts store,give them the model number and they will sell you the correct pump.good luck,if you need any more help let me know and send the model number
