Sony STR-DG600 Receiver Logo
Posted on Feb 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost my remote how to adjust my bass and treble levels from the front of the reciever
adam dombrosky
Level 2:
New Friend:
  • Expert 158 Answers
  • Posted on Feb 11, 2011
adam dombrosky
Expert
Level 2:
New Friend:
Answers
158
Questions
0
Helped
37632
Points
442
Hello,i hate to be the bearer of bad news but to change almost everything on that model you need the remote,including channel levels ,bass and treble etc...
I need to adjust bass and treble on the 65uk 7500 model
  1. Turn on your LG 65UK7500 TV and ensure it is connected to a video source.
  2. Press the "Settings" button on your TV remote. It is usually represented by a gear or cog icon.
  3. Use the arrow buttons on the remote to navigate to the "Sound" or "Audio" settings. Press the "OK" or "Enter" button to access the sound settings.
  4. In the sound settings menu, you should find options for adjusting various sound parameters, including bass and treble. Look for options like "Equalizer," "Audio Settings," or "Sound Mode."
  5. Select the option that allows you to adjust the bass and treble settings. It may be labeled as "Bass" or "Treble."
  6. Use the arrow buttons on the remote to increase or decrease the levels of bass and treble according to your preference. Some TVs may use numerical values, while others use a graphical representation.
  7. Once you have adjusted the bass and treble settings to your liking, press the "OK" or "Enter" button to save the changes.
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
1helpful
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
2helpful
Hi, what is philips mcd908 remote control code?
try 31266 31990 32311 32341 32459 (if it's a home theater system), or 12434 12205 12084 12056 11506 11389 11354 11340 11267 10675 10646 10539 10503 (if it's a DVD system) ...
assuming your universal remote has the equivalent (button) functionality to adjust bass and treble.
Zone 2
I would consult your owner's manual but I don't think you can adjust the bass/treble levels on the zone 2 outputs.
1helpful
2helpful
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
1helpful
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
