And old CQ56, super old that.
no oS stated, XP the virus magnet?
who asks for ps bios password or windows login screen.?
did you remove all other usb devices, fur SURE MICE?
id say virus infected.
then bad pad driver,
in device manager, see that pad there, click update
do so , online.
C56 tells me nothing the model has numbers at the end
if still running HP windows,(not hacked with MS disks)
the drivers for HP pad are at HP
but i can look for you lacking that a full model number.
here ill guess to teach you how HP works
CQ56-100us (us means us keyboard there)
ill pretend you said XP 32bit
and land here
then got the driver for XP here called.
Synaptics TouchPad Driver for Microsoft Windows XP
15.0.18.0 Rev. A (get it load and and use only that if i guessed right.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq56-100-notebook-pc-series/4247498
SOURCE: Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
SOURCE: the touch pad on my compaq presario CQ60is not working
The drivers for the device may be corrupted or uninstalled. Please update/reinstall suitable drivers using the drivers cd (supplied by compaq) and restart your system. This will definitely solve your problem.
SOURCE: i have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
SOURCE: Compaq Presario CQ50 + over sensitive touch pad
Try the mouse settings in the control panel, also try uninstall any touchpad software and remove any touchpad software from running when the pc boots.
To do this either type msconfig into the run/search box or a program like cc cleaner under tools/startup
SOURCE: How do I enter my
Follow the bellow link ,from here you can setup the BIOS.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph07110
Hope this helps.
