Panasonic PV-GS35 Mini DV Digital Camcorder Logo
A
Anonymous Posted on Jan 11, 2018
My Camera just shut off by itself; with full batteries. It wont eject the miniDV and it wont turn on. I"ve tried everything; even pushing the reset button; I cant get it to turn on; or even give me some hint as to why or what its malfunction is.... My camera is Model PB-GS35 with 26x optical zoom
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Mar 29, 2006
SOURCE: Panasonic PV-GS31 won't FOCUS
Just a hunch as sometimes the micro will get scrambled so take off the battery as well as the battery or batterys for the date and time. and let the unit sit for 24 hours power back up as see if that cleared your error If not send away to get repaired.
jerelo
  • Posted on Dec 25, 2007
SOURCE: Camera says "Push The Reset Button" Won't turn on
go to this site: http://www.fixya.com/support/p399886-panasonic_palmcorder_pv_gs15_mini_dv/manual-7042/page-60
I had the same problem, just read info on site tried another tape and problem solved. The tape was incompatable.
Anonymous
  • 4 Answers
  • Posted on Feb 21, 2009
SOURCE: NEED HELP
G'day,
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
Hope this helps someone
Anonymous
  • Posted on Apr 06, 2009
SOURCE: Panasonic 26X Optical Zoom PV-GS31 Camcorder Power on Problem
One or two parts are most likely faulty. They are fairly easy to replace.
One is the power unit on back where all connectors are made to the unit. The other is a small board right next to the power unit and has the on board battery for date and time. Hardest part of the repair is removing the case. The power unit is on sale on e-bay. The other part may be harder to find, but not impossible.
Durga Pratap
  • 17 Answers
  • Posted on May 14, 2009
SOURCE: I am looking for a panasonic PVGS15 minidv
Hello Cassie,
Cassie, please use the link below to download the required manual of your choice.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/Other-Camcorders/model.PV-GS15
Vivitar T328 battery issue
yup, your batteries are dead, buy new ones.
Old ones are not holding a charge
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
My Fuji XP digital underwater camera says "card protected" every time I turn it on. I've tried numerous memory cards and even made sure all of them were unlocked (because I've inserted...
Could be the locking switch inside the camera itself. Sometimes they get jammed, but can easily be reopened by prodding/pushing on (from the outside) with a toothpick. See this link.
Jul 31, 2011 • Cameras
3helpful
I have the JVC digital minidv camcorder, Model No. GR-D270U an it keeps telling me it's in safety mode and I can't even get the tape out beause the door opens but it's like the mechaism to pop...
After trying the remove-and-reattach-battery exercise, I would suggest you go to the menu and find the setting for initial setup. Select that - which may reset the system.
If not.. then try going to the clock and change the date/time settings, turn the camera off, remove-and-reattach the battery. Re-power the camera, go back and change date/time setting to what's current. And try to eject the tape.
On one of our analog video cameras it seems like there was a tiny little hole someplace on the side of the camera that you could use a tiny small thing like a toothpick to press in there to accomplish a Reset. (It will have tiny raised letters saying "Reset" right beside the little reset hole.)
I have just downloaded the camera on to iphoto and have cleared the camera memory . I clicked the eject icon on iphoto and once cleared unplugged the USB download cable . I have just pushed the power...
Sounds like you did two things wrong...you deleted/erased/or formatted the camera using the computer. You disconnected the camera without using the "safely remove hardware" function.
1helpful
2answers
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
Sony DCR PC9E - Handy Cam - Nothing is functioning: Here What I did. I was trying to eject the MiniDV, the ejected miniDV struck in between while ejecting, then I presssed the reset button of the camera,...
hold reset with batt on cam. then place on wall charger. back and forth till it ejects tape fully. if this doesnt work flat rate to send in usually is about 250
Panasonic PV-GS150 wont eject
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Camcorder Canon ZR 200
First if you have a very bad tape (miniDV) (hard to turn by your hand) the camera will automatically eject coz it cant load the tape to it. it is not a head problem. It seems that you have a mechanical loading issue here. But try to put new miniDV tape. ANd post here what happen. PS Dont use compress gas to clean it you might put new problem. Please use only the head cleaner tape (MiniDV) if you want to clean the head. Hope this may help you
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
