Question about Casio 76 Key Smartmedia Keyboard
I need the pdf service manual for WK 3700 - Casio 76 Key Smartmedia Keyboard
  • 140 Answers
Go to www.casio.com support. If that dosent help go to contact us and call directly
Posted on Feb 11, 2011
Anonymous
SOURCE:
Casio wk 500 fade screen
Screen Contrast is adjustable.
Read Page E10 of User manual
If may download English User manual fromhttp://support.casio.com/storage/en/manual/pdf/EN/008/WK200_500_EN.pdf
Jan 20, 2014 | Casio Music
How do you replace the adaptor jack on a Casio WK-1200 keyboard ? is it easy ?
Unfortunately the adapter jacks are a bit of a weak point on many keyboards but it is quite seldom the jack socket itself that is at fault.
Often the sockets are soldered directly on to the printed circuit board and are prone to either one of the soldered legs breaking, or even the circuit board itself cracking around the jack socket.
Whilst it is generally possible, with care, to resolder a broken leg on the socket if the actual circuit board has cracked the whole board will have to be replaced.
If the actual jack socket itself is damaged it should be possible to snip through the legs and remove it before soldering a new one on to the stumps of the old legs. this is likely to prove easier than trying to solder directly onto the circuit board, unless this is something that you are experienced at doing.
Apparently you can purchase a full service manual for the Casio WK-1200 here for a modest price but I have not used this source myself so cannot vouch for how good it might be.http://www.tradebit.com/filedetail.php/2084335-repair-manual-casio-wk-1200-electronic-keyboard
Feb 02, 2011 | Casio Music
"wk-3700" is wrong. Where can I buy parts to it?
If your located in the USA here is casio's USA service and Spares Department:
Casio Parts Department 1-800-223-2001
Parts Distributors
This list is subject to change without notice.
Official Parts Distributors Listing.
California
Pacific Coast Parts Dist. Inc.
15024 Staff Court., Gardena, CA 90248
Tel: 310-515-0207, 800-421-5080
Fax: 800-782-5747
mark_link_def.gifwww.pacparts.com
mark_link_def.giforders@pacparts.com
New York
American Perfit Crystal
520 8th Ave., New York, NY 10018
Tel: 212-246-8292 (NY), 800-345-0537 (Outside NYC)
Fax: 212-265-4085
mark_link_def.gifwww.americanperfit.com
mark_link_def.gifinfo@americanperfit.com
If your in another country head to:
www.casio.com
and you can locate your region and click on support/spares tab at top of page and it will give you a list of contacts in your region.
thanks,ben
Jan 04, 2011 | Casio Music
My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Nov 21, 2009 | Casio Music
How to save setting changes on Casio WK-500 keyboard?
This is a link to WK-500 owners manual.....SD Card information is on pages E-59 thru E-64...
http://support.casio.com/pdf/008/WK200_500_e.pdf
Oct 22, 2009 | Music
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Casio 76 Key Smartmedia Keyboard Logo
365 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Norman  J Weimar Jr
Norman J Weimar Jr
Ekse
Are you a Casio Music Expert? Answer questions, earn points and help others
