Hi,All the RCA sockets are inputs so you won't be able to plug in your heaphone transmitter into those.
From what I can gather you will need to plug the headphone transmitter into the 3.5mm Jack socket located on the right hand side of the TV near the RCA sockets.
If you only have RCA plugs on your heaphone transmitter you will need one of these pictured below.
You can get them from Maplins electronics or Radioshack if in the us or any good audio outlet.
Hope this helps.
You will use the RED and WHITE RCA AUDIO LINE out to feed your SONY WIRELESS headphone transmitter. Is that the way you have them hook up? You also want to check and see the on screen TV audio setup to see if the AUDIO LINE OUT is set to 'FIXED' or 'VARIABLE'.
Please leave rating if it helps.
