Follow these steps to program the remote control.
NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to
control.
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand. If your brand isn't listed, use one of the Code Search
methods to program the remote control. (Refer to pages 3
and 4 for Manual and Auto Code Search methods.)
Note: You can also use the online code finder at
www.rca.com/codefinder to find the best code for your component
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited.
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
remote pointed at the IR sensor of the component you are currently
programming the remote to control.
6. To confirm that the component key is programmed with
the correct code for maximum functionality, test the
component. Attempt to control a variety of the component's
functions with the remote. If some of the features of your
components do not work, try programming the remote with
a different code in the list until you find the code that allows
the remote to control the majority of your component's
functions. Different codes can provide different levels of
functionality
OK.
10017, 10154, 10451, 10236, 10463,
10180, 10178, 10171, 11394, 11963
1# Manually turn on the component you want the remote to
control.
2# Locate the enclosed Code Lists. Find the list for the
www.rca.com/codefinder to find the best code for your component.
3# Press and hold the component key (TV,
4# While holding down the component key, consult the
5# After the fourth number is entered, the illuminated ON•OFF
Code Entry.
6# To confirm that the component key is programmed with
functionality
OK.
control.
Code Entry.
functionality
Ok.
