Hi, i have found the codes and instructions.
Toshiba Codes - 2015.2049, 2051,2055, 2065, 2093, 2116
I. Turn on the component to be programmed.
2. Press and hold the button on the remote you want to program.
3. Enter the code from the code list.
4 Release button, and then press ONeOFF to see if the component responds to the remote commands. If it doesn't, try pressing the component button and then ONeOFF again.
5. If you get no response, repeat these steps using the next code listed for your brand, until the component responds to the remote commands.
If none of the codes work then try a code search. Instructions below.
The following instructions can be used to program the remote to control each of the devices connected to your TV. If you want to exit the automatic code search without programming any of your devices, press and hold CLEAR until the LED turns off.
I. Turn on the device you want to control (VCR, SAT, etc.)
2. Press and hold the button you want to program (VCRI, VCR2, etc.) While hold'Ing the device button, press and hold ONeOFF until the red light on the remote turns on, then release both buttons.
3. Press and release PLAY, then wait 5 seconds or until the LED stops flashing. At this point the remote is searching for the correct code to program. If, after 5 seconds, the device you want to control does
not turn off, press PLAY again to tell the remote to search the next
set of codes. Continue pressing PLAY until the device turns off or you have searched through all of the codes. There are 20 total sets of codes. If the device does not turn off after pressing PLAY 20 times, then the remote cannot control that particular device. If the device you want to control does turn off:
I . Press and release REVERSE, then wait 2 seconds. Repeat this step until the device turns back ON.
2. To finish, press and hold STOP until the red light on the remote turns off.
