Question about Reliance Water Heaters
Is my water heater still under warranty leaking water on top of heater and out from bottom and from plate
1) If water heater is leaking, I suggest you protect yourself first.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
2) You have to do some work to find out if tank is under warranty.
-Contact manufacturer: http://waterheatertimer.org/Water-heater-manufacturers.html
-Contact installer: If plumber installed heater, then installer backs warranty for some manufacturers. If you installed heater, then warranty is less or void
-Look at paperwork and manual that came with water heater and read about warranty coverage
-Look at markings on tank to see if tank is 6 year, 15 year etc
-Warranty is based on date of manufacture: To find date of water heater, look at serial number located on label on side of tank:
Open link below for serial number decoder by manufacturer.
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) If tank is older than 6 years, and tank label shows this is a 6-year tank, then tank is no longer under warranty.
If you have a lifetime tank, then warranty is in effect, so contact manufacturer.
Open following link to see troubleshoot checklist for leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Other things to consider:
-If tank rusted out after a few years and installer did not install a jumper wire between hot and cold pipes, then tank warranty will probably not cover tank.
-If tank rusted out and you have water softener, and did not inspect anode rod or maintain water heater, then you did not read manual or maintain heater, and warranty might not cover problem.
-I suggest you read water heater manual cover to cover so water heater will not start leaking.
Other useful links:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Posted on Feb 13, 2011
6ya staff
SOURCE:
What is causing the water leak and how to fix it.
When water heaters start leaking, it's time to replace it. Check your warranty, maybe you can get a free replacement. Some models have a 10 year warranty. Good luck!
Feb 21, 2016 | Water Water Heaters
Leaks bottom
Usually this is actually from the bulb inserted into the tank, if not the gasket may have issues. Contact a local technician, this may be covered under an Amtrol Warranty.
Nov 18, 2013 | Amtrol Water Heaters
Water meter is ticking away. No sign of water or
If you have a gas hot water heater, water may be dripping onto the baffle plate at the bottom and vaporizing whenever the burner fires. There would be no evidence of water under the heater in this case. Yes, I speak from experience. Also check exterior sill cocks for leakage as one might be open just a tiny bit. If you wait for freezing weather, a leaky sill cock will grow a "beard" of ice.
Oct 30, 2013 | Rheem Water Heaters
Water is not getting hot
1) Copy following link for detailed troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) How are you testing a 240Volt water heater and getting 12.5? Or 60?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 15, 2012 | Whirlpool Water Heaters
We have a ge electric water heater - last night we set a new jug of detergent on top of it over the electric plate on the top of the unit - it had a hole ( small leak) in the bottom - it leaked all night...
You flooded water heater wiring compartment with detergent, and the wires were shorting so you turned off power and cleaned detergent. Now water heater doesn't work.
1) The heat from shorting might have tripped ECO reset button.
Open top cover on water heater, and push in red reset ECO button.
http://waterheatertimer.org/images/Jly-022-thermostat2-175.jpg
Be sure to re-install insulation and cover.
Other steps:
2) Turn off power. Remove wire nuts. Cut off copper ends of wire, and re-strip each wire so fresh copper shows. Make sure no detergent is on the copper. Use new wire nuts and twist very tight against copper wire.
3) Cut back burned ground wire. Remove ground screw and clean thoroughly. And then reattach clean copper to ground screw.
4) Turn power back on.
5) If water heater still does not work, then test across top two screws on upper thermostat for correct voltage.
http://waterheatertimer.org/images/Jly-022-thermostat3-175.jpg
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | General Electric Water Heaters
Water leaking at bottom of cylinder.out side of pipe at bottom.
Depending on age and condition, If you don't see any noticable leaks where pipes are fit on top of the tank, you will more than likely have to replace the heater. Try turning the power off to unit and remove the inspection plate(s) on the side. See if you can tell where the water is coming from. If you see it is leaking around the element(s), you may want to try to remove the element(s) and apply teflon tape or sealant to the threads and re-install, do not over tighten. You may have a crack in the fiberglass tank. Water is leaking down into the metal tank which is a protective cover for the fiberglass tank that stores the water. The pipe at the bottom is probably the drain for the tank. If you are going to try to re-seal the elements, you will definately have to cut the power nad drain the tank first.
Aug 22, 2011 | Water Heaters
I have water seeping from the bottom of the unit.
That is very common when the water heater springs a leak...the water will seep through the inside and run out the bottom...
Check to see if it is still under warranty...if so then call the installer to have it replaced...if not then replace it with any new one..
heatman101
Jul 12, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Leeking water from bottom
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
Nov 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Leak in the bottom of insinkerator 1-81 near reset button there are two little flange looking things one is leaking rapidly when water is on
depending on the age it sounds like you may have to replace the unit,, insinkerator is the best on the market so when they leak it;s time for a new one ,, if not to old and under there warranty they will send some one to ifx it just call the 1-800 number on the unit
Jun 13, 2009 | Emerson Insinkerator 2.5 Gallon Water...
I have an old rheemglas fury 22v40 that's leaking from the bottom. What could be the cause? Also, it DOES need replacing, Who does installs at no cost at the time of purchase?
my top element to the hot water heater is working but my bottom element isnt there both brand new elements and im just not getting power to the bottom element but i have power to the top element is it possible that the top heats first and the bottom heats later running out of options!!!
Dec 06, 2008 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
370 people viewed this question
Top Reliance Water Heaters Experts
Gil Shultz
Thomas F. Schneider
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
