Mytoshiba 32av600a keeps changing inputs on its own, now it is getting progressively worse and every time i try and use either the remote or change volume or channel using the tv it flicks input. i have checked the remote and nothing is stuck, and heave removed batteries, i have unplugged the tv and restored factory settings but nothing has worked
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Hi there! this is Kimberly Escobar with Dish Network Customer support, I just ran across your post and would like to help you out by providing you the information that can help get this issue resolved. To program the remote to your Viore T.V you can try code 738. What you would need to do is press and hold the clear T.V button located on the upper left hand corner of your remote (you will see all the other top buttons light up) then you will let go of the T.V button and enter the number 738 followed by the pound (#) key, notice you will see the clear T.V button flash 3 times. After this you can try the volume function and turning on and off your T.V. If it works you can try changing inputs on the T.V by pressing the T.V/Video button or Input button on the remote. Unfortunately we can't promise our remote will control all the functions on your T.V we also have this link available that you can as well find very helpful http://www.dishnetwork.com/SupportSection/remote-setup and you are more than welcome to also contact us directly. Thank you hope this helps.
try replacing your fuel filter, With big temperature swings this time of year, condensation (water) forms in fuel tank, Prior to changing fuel filter run a bottle of STP gas treatment or a good injector cleaner through it.
Ours is crapping out just like yours. Picture goes out, "black and white squiggles" appear in the top left of the screen then TV input appears, then it either repeats or gives me my picture back. This happens with both the HDMI slots (tested all 3) and both Component slots. Seems like the bulb or a circuit board on the TV is faulty. What a piece of ****, never spending another dime on LG products. I did get it to come back by hitting the back of the TV with a good slap, but it gets really annoying.
I was told by Sanyo and Toshiba that I will have to have a Sanyo remote in order to change the tuner from TV to CATV which he said is causing me to be unable to get above a certain channel and also to change the settings in order to use the Progressive scan cables, so I have emailed a remote finder site and they are trying to find a Sanyo remote for me.
