You are going in the right direction. Use that warranty to the MAX!
In a nutshell, the problem is probably related to the sets power supply.
I have answered quite a few plasma TV problems and most are centered around the power supply.
It takes a huge amount of current to "ignite" the plasma to get it to glow. Once it is lit, current is constantly fed by scanning through over a thousand "power" lines on one side of the screen and scanning over a thousand "address" lines on the other side. The sparkles and lines can be a secondary effect of its not being able to regulate voltages correctly.
The power supply in a plasma set has its work cut out for it and it is very important to make sure that it gets the ventilation you manual says it needs.... blocking the vents can quickly overheat a plasma set.
Some FYI stuff about plasma TV's....
1- due to their very nature, a plasma picture will dim over time. The materials that make up the power and address lines are slowly "sputtered" across the very thin gap between them and eventually darken the inside of the glass. This is slowed down some by coating the insides with a clear magnesium oxide film during manufacturing.
2- It is very easy to "burn" an image into a plasma TV screen, so avoid playing video games on it and don't let a "still" screen stay on more than a minute or so.
3- The screen itself is made of common "soda glass" - the same as window glass, and is usually 1/4" thick on each side (a little over 1/2" total) and this accounts for most of the sets weight. Between the two glass plates, there is a small gap that is made by fusing thin glass rods into the screen. In this gap is a vacuum, with a small amount of a rare gas mix added. Be careful not to hit the screen because if it cracks, vacuum integrity is compromised, the gas escapes, and your TV will be worthless.
Good Luck!
V.
SOURCE: my Panasonic VIERA TC-P50G25 50-Inch
hi good day since the problem suddenly shut down, this is how are you going to isolate and fix the problem first try to unplug for an hour to discharge excessive voltage at power supply and to reset the processor at the main board. now after an hour try to plug and turn on the unit. then if no power at all and even standby light indicator your power supply is bad. now you will need to open the cover to access the power supply, look for blown fuse first and burn parts just consider also leak and bulged capacitor it seems their is a blinking error sometimes low voltage. replaced capacitor with same voltage and atleast 105c temperature rating, panasonic brand much better you can order parts at www.digikey.com .just tell me if its work thanks good luck i hope it will help you.
