Question about Panasonic Lumix DMC-FX30 Digital Camera
Mode dial is not in the proper position - Panasonic Lumix DMC-FX30 Digital Camera
    Guru:
  • 679 Answers
I had the same problem try this tap the outside of the dial lightly while turning the camera on it should basically "pop" right out if it didn't work it needs to go to a panasonic service technician. most likely the lens is damaged and the mode switch
Posted on Feb 13, 2011
Anonymous
SOURCE:
Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Mar 22, 2012 | Nikon S8100 Digital Camera
My fz28 is stuck in "mode dial is not in proper position'. How do I open the top and fix the problem? Thanks
My mode dial FZ28 is only loose and sometimes I get the same error message. A shop gave me this price for replacing the mode dial: around $100 for the mode dial, $25 for the man-work (French prices). But I don't know if it can be repaired (not changed). If you have fixed yours, any idea will be apreciated. Thanks;
Dec 17, 2010 | Cameras
When you turn it on the screen displays "mode dial in not in the proper position." Mode dial does not turn properly.
Something seems to be broken or off between the mode dial and the switch. It also may have broken internal parts.
I have had a camera with a similar problem. It was that the small switch inside was broken, and could not be repaired.
These mode switches can be changed, but will require a digital camera repairman to do such a job. It also could be sold for parts/repair on a site such as Ebay.
Aug 31, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
Screen reads..."Mode dial is not in the proper position"
I had the same problem, so bought a few precision screwdrivers and took the back off. Be careful, but you can release the top section and on the bottom of the dial is a few plastic spacers which had squashed. I straightened these out, carefully put it back together, and this solved it. I think these spacers hold the electronin dial in place, hence why it comes up with " not in proper position ". If you fancy trying, it only took me 5 minutes and I know nothing about electronics.
Tom A
Sep 03, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
MODE DIAL IS NOT IN PROPER POSITION
Try turning the mode dial again. It may not have been turned properly.
Jun 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
how to take good pic beside use the iso mode
May 19, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Mode Dial and Lens Problems! Nikon Coolpix 4600
i had the same problem try this: tap the outside of the dial lightly while turning the camera on it should basically "pop" right out!!!!!!!!;)
May 04, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FX30 Digital Camera Logo
412 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
