SOURCE: Camera says "Push The Reset Button" Won't turn on
hi sir it is quiet claer that you have a mechanical problem the guides inside the mechanism are stuck ,and or , you have a loosen top of one guide too this is a matter for a qualified person to check , but that is the fault sharply. regards and plz . don't forget to perfect rate as i help you .thx
go to this site: http://www.fixya.com/support/p399886-panasonic_palmcorder_pv_gs15_mini_dv/manual-7042/page-60
I had the same problem, just read info on site tried another tape and problem solved. The tape was incompatable.
SOURCE: DV tapes will not load
The problem you are having is caused by the grease that is used to move the reel positioning mechanism has hardened. Once the grease hardens the reels can no longer position properly. The grease needs to be removed and replaced. Do not remove the cassette assembly, only remove the top plate. Also check the pinch roller grease, make sure the pinch roller moves freely.
SOURCE: Panasonic NS-DV 65 video camera, Tape not detected?
TRY THIS, (CREDIT TO LABBER) IT WORKED FOR ME
I did have a similar problem as above, and has not been able to use the camera for a long time as power turns itself off in less than 2 mins. I tried the solution #3 (by labber) above. which i have copied and pasted below .
1. Take out the tape - mine stayed on longer (without blinking) when the tape was not in.
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on you should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS HOPE THIS HELPS.
EBEN
SOURCE: Problem with Playback and Record on camera
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
