SOURCE: tv will not turn on.
Yes, I fixed the problem by replacing the lamp. I was able to find one on ebay for $109,00, Thank you
SOURCE: What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Testimonial: "A lot more help than I got from Panasonic!!!"
SOURCE: I am having a problem
Hi and welcome to FixYa. I am Kelly.
This can happen when there is a power failure. Usually there is a PF in the display but you can also get 88:88
Try this first: Press stop / pause or cancel then clock and try and set the time. If at that time you do not get any beeps your control board most likely has a problem. To dig deeper if you wish to have more assistance I need your complete model number to possibly troubleshoot.
Thanks for choosing FixYa,
Kelly
SOURCE: Panasonic TCP58S1 has no pic. or sound. Red light blinks 9 times.
It's dead. 9 Blinks means the display adaptor is dead. If it's still under warranty, you're covered.
SOURCE: PANASONIC TV MODEL # PT 56WX33G BLINKS 5 TIMES
The symptom is no quick fix because your unit have an out of regulation condition in the power supply that is caused by faulty parts in that area or in its load. Leaky capacitor, cold solder is commonly caused by this problem. It will give an unregulated supply cycle and once sense by the processor it will not power up the unit unless isolated. Also to consider faulty IC regulator and open fusible resistor in lined with it. This is technical and need to be check by the professional. I've advice you to send it to your nearest Panasonic Service Center.
Check also if it is still under warranty, avail it because the manufacturer of your tv will fix it for free or a little charge only.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
