SOURCE: oil drain plug
Follow the hose that goes to the frame from the oil tank. Loosen the clamp and pull.
SOURCE: 2003 Harley Davidson Sportster 1200 Custom Tachometer kit
The only idea that i can come up with is that you dont have a good ground..or the guage was bad when you bought it..i hope this..Keith
SOURCE: My Harley Davidson Sportster 1200 cuts out during exceleration
The volt reg could be getting over volts,the charging system may need to be tested to determine whats going out.The voltage output from the stator goes up with more rpms,when the voltage regulator gets too much it dumps it into the grounding side of your electrical system(somethimes the ground wire will get smoking hot)This dump of power could also kill the rest of the system.Make sure your carb is clean (remove trash from inside the jet and filter) just to be sure its not just dirty fuel system.
