Question about Sennheiser HDR-45 Consumer Headphones
How to tune the headset? - Sennheiser HDR-45 Consumer Headphones
Static noise coming from headset. The headset has been making this noise for 3 or more days.
Most headphones (wireless) have a tuning wheel that allows you to find your headphone channel pair to base set. It sounds that while checking your foam ear piece you may have moved this dial / wheel. After locating (probably near volume) the control for tune, place headphones on and slowly move control for tuning. You should hear something move control to strongest signal.
your base also has settings switch for channel helpful if you have more then one pair in house, on different TV. Play with both to find best volume.
Sep 04, 2016 | Jabra GN9330 Wireless Headset
I cannot set up h110 headset in my windows xp
Just connect the two connectors to your computer sound card.
Your computer should have a pink connector for the mic and a green for the speakers. You also could plug the speaker (headset) into the orange if your sound card has that colour.
Then you just adjust the volume for the headset with the sound settings of the computer.
The program you want to use the headset with, will also allow you to fine tune the set.
Jun 08, 2014 | Logitech H110 Headset - Stereo
Tune being played
I would contact Motorola and find out what the problem is with your headset.
Mar 02, 2009 | Motorola Mobility H500 Wireless Headset
Samsung E250 Radio
Radio works only with the headset plugged in which is used as an antenna, I believe only original headset works..
Nov 11, 2008 | Samsung SGH-U600
Setting up my H350 on a new phone
when hooking up your bluetooth hold your volume and your call button at the same time. .then your head set indicator light stays on .then you can set up your phone,your phone will ask for a code the code is 0000 that will set your headset to your phone.
Sep 18, 2007 | Motorola Mobility H350 Wireless Headset
Sennheiser HDR-45 Consumer Headphones Logo
283 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
