the aspect ratio is the picture size control
when you select aspect ratio you have to move with the arrows to get the size that fits the panel the best - go ok then exit to save the setting
if that doesn't work the the tv will need attention in a repair shop
use the tv's remote to adjust the picture size under settings. Some newer cable boxes have a service menu that can be activated to set the pic right at the box but that depends on make and model.
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
athacker, This is a result of the aspect ratio being set to the wrong setting for what video source you are watching. Go into your menu and select picture>aspect ratio>normal. Then play with the five different modes to maximize the picture for the source you are watching.
I hope I was able to help. Please rate this answer if I was able to do so.
adjust the ASPECT RATIO of TV using the MENU button....remote control if an original will have a button on the remote to change ASPECT RATIO on TV....ZOOM button can cause that also!
You need to change the aspect ratio of the screen. The cable box remote has an aspect ratio button and the tv remote also has an aspect ratio button or picture size button. You are probably on a zoom aspect since its too big.
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
