Garden Logo
Posted on Feb 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get my lawn mower ready for spring time use?
Joseph Mueller
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 346 Answers
  • Posted on Feb 14, 2011
Joseph Mueller
Expert
Level 2:
Mentor:
Answers
346
Questions
Helped
171882
Points
784
This is what a "General service" looks like at www.arcolawn.com
  • (Mower 2 cycle GS)
GENERAL SERVICE:
1. SHARPENED & BALANCED BLADE
2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS
3. REPLACED SPARK PLUG
4. FLUSHED FUEL SYSTEM
5. CLEANED CARBURETOR HOUSING
6. LUBED CABLES
7. CHECKED OIL SEALS
8. SERVICED AIR FILTER
9. CLEANED EXHAUST PORTS
10. TESTRAN & ADJUSTED.
  • (Mower 4 cycle gs)
GENERAL SERVICE 1. SHARPENED & BALANCED BLADE 2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS 3. REPLACED SPARK PLUG 4. CHANGED OIL 5. FLUSHED FUEL SYSTEM 6. CLEANED CARBURETOR 7. LUBED CABLES 8. CHECKED OIL SEALS 9. SERVICED AIR FILTER 10. TEST RAN & ADJUSTED.
  • (rider tuneup)
Tune up
1.TIGHTENED ENGINE MOUNTING BOLTS
2. INSPECTED BOTTOMOIL SEAL.
3.TEST GOVERNOR OPERATION & ADJUSTEDRPM'S.
4.CHECK SHAFT BEARING.
5.REMOVED BLOWER HOUSING &CLEANED COOLING SYSTEM.
6. REPLACED SPARK PLUG
7.CHANGED OIL.
8.REPLACED OR CLEANED AIR FILTER.
9.ADJUST FUEL/AIR MIXTURE & SPEED LIMIT SCREWS.
10.REPLACED FUEL FILTERS AS REQUIRED.
11.CHECK FUELLINES, VALVES, & CLAMPS.
12.INSTALL FRESH FUEL IN GASTANK.
13.SHARPEN BLADE(S) & CLEAN UNDER BLADE COVER.
14.CHECK DECK, EXAMINE BELTS, PULLEYS.
15. EXAMINETRANSMISSION/DIFFERENTIAL FLUID LEVELS,
16.CHECKGREASE FITTINGS, WHEELS, WHEEL BEARINGS, HEIGHTADJUSTER.
17. CHECK CABLES & CONTROLS ADJUST BRAKE &CLUTCH.
18. CHARGE & TEST BATTERY. (IF EQUIPPED).
19. TESTSAFETY SYSTEMS.
20.REMOVED CYLINDER HEAD & CHECKEDCYLINDER FOR WEAR/DAMAGE. CHECKED ROD BEARINGPLAY. 21.CHECKED VALVES FOR PITTING, WARPING, CARBONBUILDUP & SEATING.
22.CHECKED VALVE STEM CLEARANCESFOR EXCESSIVE WEAR.
23.CLEANED CARBON BUILDUP FROMCOMBUSTION CHAMBER.
24.MACHINED HEAD FLAT.
25.CHECKEDTIMING KEY FOR DAMAGE.
26.CLEANED OR REPLACED POINTSAND CONDENSER (AS NEEDED).
27. SET TIMING. ADJUSTEDMAGNETO AIR GAP.
28.CHECKED THROTTLE SHAFT FOREXCESSIVE WEAR & REPLACED IF NEEDED.
29.DISASSEMBLED& CLEANED CARBURETOR. REPLACED DIAPHRAGM, NEEDLE &SEAT, NEEDLE VALVES ETC. AS NEEDED.(see carburetor section)
I hope this helps! get parts for the service at a dealer like www.arcolawn.com
Testimonial: "Thanks for the detailed list! "
Anonymous
Level 2:
  • Expert 49 Answers
Anonymous
Expert
Level 2:
Answers
49
Questions
Helped
8318
Points
147
Well you should change the oil if its been sitting for awhile. Then change the spark plug paying attention to set the gap correctly. check and clean all air filters and fuel filters. Replace as needed.
Take off the mowing blade and inspect for any damage. If it looks good sharpen or have sharpened and put it back on.
also add fresh gas with recommended octane.
after this you should be ready to go for another great season of yard work.
3 Related Answers
Anonymous
  • 313 Answers
  • Posted on May 29, 2008
SOURCE: Lawn mower
check out murray & tecumesh website
Anonymous
  • 124 Answers
  • Posted on Sep 20, 2009
SOURCE: have a craftsman 18.0hp riding lawn mower. Has a
Most likely it is the governor spring but you could have a stiff throttle shaft or a needle that is not closing properly allowing the carb to flow too much fuel into the engine.
mickey813
mickey813
  • 472 Answers
  • Posted on Oct 07, 2009
SOURCE: The clutch spring on my riding lawn mower broke,
WHAT MOWER DO YOU HAVE
Sears craftsman manuals?
You can't get sears manuals. If you remove the recoil assembly and turn it over you will be able to turn it. If the spring catches and starts to wind then you know your spring is good and you don't have to replace it. If it doesn't spring when wound replace spring. When ready turn till spring is fully wound ( can't wind anymore without force) then back it off until the rope holes line up. Install rope and handle and retract slowly. Pull handle a few times to make sure its not sticking and retracts properly. Reinstall on engine
Jul 27, 2014 • Garden
tip
How To Replace The Pull Rope On Your Lawn/Push Mower
Although you may not have the exact mower that is in the video, all of your smaller mowers are pretty much the same.
Good Luck with your project!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Lawn Mower, Push Mower, Pull Rope, Coil Spring, Self-Propelled, & Grass
on Aug 08, 2011 • Garden
2helpful
Why do my rear wheels lock up pulling machine backwards?.
your drive will driver dogs are full of dirt you need to remove both wheels and clean the dirt out the dogs are spring loaded be ready for parts to spring out maybe depends on how much dirt
Lawn mower governor spring connection points. I know one end goes on the governor lever ,just having a hard time figuring out where to connect the other half of the spring. Model #917.387160 Engine model...
go to a lawn mower shop and ask to look at a diagham of the motor it should show were it connects or if the mechanics are friedly they may do it for you
Aug 05, 2013 • Garden
5helpful
How do i replace the side flap door on my mower
There is a rod that acts like a hinge pin. There is also a spring that keeps the flap door closed. The rod goes through both the flap and the spring at the same time. You need to hold the spring under tension while sliding the pin into both pieces at the same time. A little bit tricky, but do-able.
Hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
2helpful
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Lost spring to carburetor mtd lawnmower
you can go down to any napa or hardware store and pick up a light small spring about 1/4 inch maby 2 to three inches long atach it to the throttle and your ready to go
1helpful
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
Top Garden Experts
Jay Finke
Jay Finke
john h
