Washing Machines Logo
Posted on Feb 14, 2011
We have a maytag neptune front loading washer and during a load the washer stopped and is flashing "nd" what does that mean
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Feb 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
3607
Points
63
I believe that is a No Drain situation. Check the drain hose to make sure it is not too far in the drain standpipe...It should only be inserted about 6-7 inches. If it is submerged in the standpipe water it may cause a siphoning effect and pull drained water back in tricking the pressure switch. After a few minutes of this it will error out. You may also have a blocked pump not allowing water to drain at all. I believe this unit is only serviceable from the back panel depending on which model. Lots of water mess will occur when trying to clear the pump so have many towels ready and the unit unplugged. Try taking the hoses from the pump and taking the pump out so you can see in it and clear it of hairpins, coins, pencils, socks, or many other items normally found in the pump. If the impeller does not have a slight resistance then a quick ":flick:" movement then it may be ready for replacement. This movement can be checked by sticking your finger in the pump while it is removed from the unit and try turning it 90-180 degrees before it flicks to the next pole on the internal magnet. If it feels gritty or very sluggish...or if it just spins with no resistance it is bad.
A tip before removing the pump hoses is to get a bucket or catch can and lowering the drain hose from the wall to close to ground level and see if water will flow out...that will allow you to drain the bulk of the tub water if it is not clogged completely. Just lift the hose to stop the flow until you can drain the catch bucket and repeat.
Good Luck!
2answers
My washer stopped working and is displaying the code nd, what does this mean?
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
1helpful
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Stopped with a load and water displayed a code of nd
When error code "nd " flashes remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining. This will fix your problem.
Thank you !!
2helpful
My maytag neptune washer stopped working and flashed an FL error code. Any idea what that means?
It could mean flood error.if it has stopped full of water & it wont drain out.The pump might be blocked or jammed with hair pin or other debris.
What does nd stand for
Hello, the ND showing simply means "no drain"and it is probably just something caught in the pump.It may be something like rubber bands,toot pick,a bra wire,or a lens from a flash light.
Thanks
1helpful
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
5helpful
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Top Washing Machines Experts
john h
