SOURCE: cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
SOURCE: JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
SOURCE: cd player will eject cd but wont turn on..
It sounds like the ignition or power wire isn't properly connected. I guarantee that's the problem.
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
