That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
SOURCE: monitor Samsung914v will not awake from sleep mode using Vista HP
The only thing I could find is that it's a bug in Windows Vista operating system and that make sure your Service Pack and all hotfixes are updated.\
Try this and see if it will temporarly work for you until a permanent fix comes in. before you log off, do a Crtl-alt-delete. Then click on processes. See if you can find your video card listed in the processes and right click it and then stop it. After you've stopped your graphics card then go ahead and put in in sleep mode see if it will come up. Here's the website where I found about the bug, if you want to peruse the Microsoft Knowlege base you may find something else. http://support.microsoft.com/kb/937500
If you have any questions let me know. Please rate this with 3 stars before logging out. Thanks and let me know if you have any other questions.
SOURCE: My LG L196wtq-BF went black this morning. No
We have some dis-assembly guides on our web site at: www.ccl-la.com/badcaps.htm There are not for your exact model but they should help.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: LG Flatron L196WTQ-BF Monitor will not power on
Here is a link to a How To on this monitor (and similar) they offer
cheap parts as well.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/comment-page-1/#comment-136
SOURCE: how to replace LG L196WTQ-BF Computer light bulb
Are you sure that the lamps (4) are bad and not the backlight inverter circuits.
Service manual: http://elektrotanya.com/?q=showresult&megnev=LG%20&megnev2=%20L196WTQ-BF%20&kategoria=monitor&kat2=schematics
Not all the LCD lamps can easily be removed, some of them you have the completely disassemble the screen to get the lamp asemblies out. Need to do voltage checking and caps inspection first, it should have 5vdc for the logic and 16~18vdc for the inverter circuits
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
