Question about Sanyo Televison & Video
Disc error after loading - Sanyo Televison & Video
  • Sanyo Master
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Take care.
Posted on Feb 14, 2011
6ya staff
SOURCE:
My sony mds-303 is ejecting new disc and saying disc error
I had the same problem. Take the top off and wind the loading wheel until the mechanism engages and loads - but with no disc in place. Then unplug the power and look through the top. You will see the lens. Clean with rubbing alcohol and a q tipi and dry with a clean q tip. Try playing a disc
Mar 26, 2012 | Sony Audio Players & Recorders
I have a Pioneer AVIC D3X im get a error 2 when i put in a cd
Dirty, Clean disc, Scratched disc, Replace disc, The disc is loaded upside down, Check that the disc is loaded correctly.
Mar 26, 2012 | Pioneer AVIC-D3 Car DVD Player
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
Nov 14, 2009 | 2004 Mitsubishi Endeavor
Error 0XC000000C and 0XD000001E and 0XA0000001 how would I fix these errors its on a Aspire 5315-2153 Notebook did have Window Vista as OS I tryed the backup disc I made 1-9 error OXC000000C on disc 7 I...
My 0xc000000c "Restore Failed" prompt seemed to be the result of disk surface damage on the restore disk. After burning the restore disk to a new disk, the restore proceeded normally. Try making a copy of the original restore disk to a known good blank disk.
Jul 20, 2009 | Computers & Internet
Disc will start loading than error comes up saying
The laser diode has gone bad. You will need a new lens assembly, just search google for "PS2 Lens Assembly" and you'll find plenty of places to buy them from.
Jun 14, 2009 | Sony Video Game Consoles & Games
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
Dec 21, 2008 | Car Audio & Video
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Disc Error message
UNPLUG UNIT AND LEAVE OFF FOR 1 MINUTE. THEN PLUG BACK UP AND RESTART
Mar 17, 2008 | Sony RDR-GX300 DVD Recorder
Televison & Video Logo
148 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
