Youre not linked up with your tv ,try tv2 mode or make sure the channel is set to which ever channel three or four and the dvd is set to that same channel. make sure it isnt on pause as well ,but that is your problem you arent getting a signal from your tv,check your cabling also
Are you putting a american standard disk NTSC into a PAL European tv ?
--- Please dont forget to vote this answer was helpful Many thanks ------
This can cause this problem.
Look at your tv manual / settigs to see if there is an option for this. Most tv do these days.
