There is not much to do than to set the machine in the fax mode after setting up the time and data as instructed on the interactive menu .
You need to type the STD code of cambodia and the number of the fax there which must also be active. Make sure that you enter the correct local code if the number is in sub-district.
Ask your friend to send the fax after placing your machine in fax mode.
Make sure there is dial tone and you are able to make calls using the telephone mode.
if not check the connection.
Testimonial: "Thank you. That is helpful."
