Sony BRAVIA KDL-52S4100 52 in. HDTV LCD Logo
Posted on Feb 15, 2011
Hi. My model,# is sony KDL-52S4100 . The problem is, at first turn on. it has 4 or 5 vertical lines across the sreen and the whole right side of the sreen blurry and flickering. This whole problem lasted from 15-30 minutes. Please help. this TV only 25 months old.Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
624
Points
I have the same problem - any solution?
3answers
I have tv Sony KDL-52S4100 and it has vertical lines running all through the screen and I am not sure what to do.
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
1helpful
Red light flashing 4 times
sounds like it's toast http://community.sony.com/t5/Television-Picture-Sound/Vertical-Lines-of-death-KDL-52W4100/td-p/29582
Picture won't refresh on left 1/4 edge of screen
It may and likely is a defect inside the display panel itself.
Sony kdl-52w3000 has a yello vertical line on lh side and reddish line in the middle. The left side is a little lazy slow as well. How do I fix it?
Take it to a shop for a estimate unless you want to start buying circuit boards and replacing them to see if it is a board or the display panel itself.
1helpful
BLACK VERTICAL LINE APPEARED ON LEFT SIDE OF SONY BRAVIA LED SREEN.PL HELP
Sorry to hear that!
But you have a dead row of pixels.
You should contact Sony for a warranty replacement as fixing this yourself is all but impossible.
Once again, sorry to hear this and hopefully Sony will provide you with a prompt response!
1helpful
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dark area on Sony LCD screen model KDL-46XBR4
This model of SONY TV uses a Samsung display panel, the problem you have is the panel went bad.
SONY was offering an extended warranty to change the panel free, please call SONY to check it out that if they still offer the free replacement.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
