Question about Linksys Cisco Small Business WAP4410N WirelessN Access Point PoEAdvanced Security (S7271261)
I can't enter web based configuration utility by 192.168.1.245 ip. i already reset the wan4410n ap to factory settings. how to obtain ip of the access point?
6ya staff
SOURCE:
sk8rsnuk
  • 4 Answers
SOURCE: Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Posted on Dec 01, 2008
Anonymous
SOURCE: Default IP address for symbol spectrum24 ap-4131
Try 10.1.1.1
Posted on Apr 23, 2009
Gord Thurston
  • 131 Answers
SOURCE: D-Link 2100 AP is working in Wireless Client mode.
Check in your router to see if your router is set up to be a DHCP Server. If your router and adsl are both set up to be DHCP servers, sometimes they will fight with each other and some computers seem to have problems getting adresses from this kind of setup. Make sure that only one is set up to give out adresses, then check on your second computer to make sure that it is set to obtain adress automaticaly. If someone has set a manual adress in that computer that is not on the same subnet as the router, they will not comunicate. If this does not solve your problem, try putting in manual adresses into both computers: IE 192.168.1.2, subnet mask 255.255.255.0, Default gateway 192.168.1.1 in the first, and 192.168.1.3 in the second with the same subnet and default gateway,
Posted on Nov 26, 2009
jwiggins8579
SOURCE: I'm trying to configure my
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Posted on Jan 11, 2011
SuperPhrank
  • 142 Answers
SOURCE: My WAP4400N access point had a IP address entered
If it is currently on your network you can use this utility: http://www.radmin.com/products/ipscanner/. It will scan your local network for attached devices. With it you can find the ip of your WAP and access it.
Posted on May 13, 2011
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
The router was reset. So, our AP does not work with it anymore. I reset the AP to restore it to its factory default settings and tried to follow the steps I made before in configuring the AP. but i can't...
Before you configure this device, note that when the AP is configured through an Ethernet connection, (via RJ45 Network Cable) make sure the manager PC must be set on same the IP network. For example, when the default network address of the default IP address of the AP is 192.168.1.1, then the manager PC should be set at 192.168.1.x (where x is a number between 2 and 254), and the default subnet mask is 255.255.255.0.
Open Internet Explorer 5.0 or above Web browser.
Enter IP address http://192.168.1.1 (the factory-default IP address setting) to the address location. Please refer here to the Latest User Manual for Encore ENRWI-G Page 9 onwards describes the login details.
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Encore WIRELESS LAN EXTENDER
Hope this Helps!
CreativeTECH
Jan 01, 2011 | Computers & Internet
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Redrose90049@yahoo.com
Reset There are two ways to reset the Router’s
factory defaults. Either press and hold the Reset
Button for approximately five seconds, or restore
the defaults from Administration > Factory
Defaults in the Router’s web-based utility.
How to Access the Web-Based Utility
To access the web-based utility, launch the web browser on
your computer, and enter the Router’s default IP address,
192.168.1.1, in the Address field. Then, press Enter.
A login screen will appear. (Non-Windows XP users will
see a similar screen.) Leave the User name field blank. The
first time you open the Web-based utility, use the default
password admin. (You can set a new password from the
Administration tab’s Management screen.) Click OK to
continue.
Jan 04, 2010 | Linksys WRT160N Wireless Router
NO IP or MAC displayed
Solution: IP of 0.0.0.0 means your DHCP server is not providing configuration settings to your network card. Reset router/access point by pressing the reset button with your finger, the tip of a pen, or a paper clip for at least 30 seconds. Try again! If this solution doesn't work, try turning off computer, turn off router/AP, and DSL/Cable modem. Turn on devices in reverse order. First power on modem, then router/AP, then computer. Connect to router/AP and see if it provides IP. If this solution doesn't work, your DHCP settings are not configured correctly. See router's manufacturer manual or visit their Web site.
Dec 28, 2005 | 3Com U.S. Robotics Wireless Turbo...
Linksys Cisco Small Business WAP4410N WirelessN Access Point  PoEAdvanced Security (S7271261) Logo
1,018 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
