Question about SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG)
How do you make your SMC router security enabled?
  • SMC Master
  • 7,733 Answers
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Feb 17, 2011
4 Suggested Answers
6ya staff
SOURCE:
cq92
Larry S
  • 184 Answers
SOURCE: WPA enable SMC Barricade
Turn on wireless, then WEP encryption, then add passphrase.
Posted on Aug 29, 2009
Anonymous
  • 5 Answers
SOURCE: cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Posted on Sep 07, 2009
govinda123
Prashant M
  • 2277 Answers
SOURCE: how do I enable wireless security on router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Posted on Jun 25, 2010
I am having difficulty making my network a secure network, how do I access the routers setting to enable the password?
Connect a LAN cable from your computer's LAN port to the SMC wireless router.
Open a browser and enter the SMC configuration URL.
http://192.168.2.1
The default PW = smcadmin
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 20, 2011 | SMC Barricade g SMC2804WBRP-G Wireless...
How do I set up password protection for my SMC Barricade Turbo 2404WBR Router?
Please follow the steps mentioned below and check if the issue is resolved.
  • Please open a new browser window and in the address bar type in 'http://192.168.2.1' or 'http://192.168.2.1:80' or 'http://192.168.2.1:88' and press enter.
  • The password would be either blank or smcadmin.
  • To enable Encryption or Secure the Wireless Network, follow these steps:In the router's configuration page: Click on Advanced Setup -> Wireless -> Encryption.
  • Select the Encryption type (WEP, WPA, WPA2 etc), type the Security Key and save the settings.(128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD EF 01 23 45 6D F9
    64-bit encryption uses 10 characters. Example:
    01 A3 45 F7 8)
  • The Wireless/Internet is Secured Now.
  • You can also set the password for the Router log in: Please click on Administrator settings and input the new password.
Good Luck!
Thank you for contacting.
Jul 07, 2010 | SMC Barricade Turbo Router
How to secure and setup a password for my SMC barricade G smc2804wbr router using a toshiba labtop. I do not have the intallation CD drive. please help
You need to log into the wireless router either by a computer that successfully connects wirelessly or by physically connecting with an ethernet cable. Once connected, log into the router by open a web browser (Internet Explorer, Mozilla Firefox, Google Chrome, Apple Safari), and typing the router's address (usually 192.168.1.1 or 192.168.0.1) into the Address (or URL) line. The default usernameand password is usually "admin" & "admin" or "admin" & "password". Once successfully logged in, look for a tab or link that says "Wireless" or "Security". You'll be able to change whether security is enabled or disabled, and the password associated with it. Your security options are WEP or WPA (or WPA-PSK). WPA-PSK is the most secure, but WEP is also an acceptable choice. Select the security option of your choice and either enter text into the passphrase generator or choose your own password and type it into one of the security key text fields. If you use a password that is not a plain english combination of letters and numbers, be sure to write it down so that you can enter it as needed on other wireless devices that need to access your router (ie-pda phones, game consoles, laptops, desktops, etc). Be sure to save changes so that the security settings and password is saved.
Let me know how you make out.
Mar 08, 2010 | SMC Barricade g SMC2804WBR Wireless Router
SMC Barricade SMC7004VWBR not found by Wifi toys
good day,
hope this link below will solve your problem.
routers
Feb 12, 2010 | SMC Barricade 7004VWBR Wireless Router
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
Cannot set up security on wireless router "wireless card nt found
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
My wireless lose the pasword key
-You need to access your router user interface using a wired pc to the router, by typing the router IP on the address bar of your browser then it will ask you for a username and password.
-Then on that page you will have options where you can enable again the wireless security just enable again the security from that there.
May 06, 2008 | SMC (SMC2555W-AG UK) 802.11a, 802.11g/b...
SMC 7004 VWBR router
enable wireless in router and connect threw xbox
Apr 08, 2008 | SMC Barricade 7004VWBR Wireless Router
Problems with SMC2804WBRP-G not detecting/connecting with Windows Vista
i have a similar problem with SMC7904WBRA2 Barricade router. I can only intermittently connect from my Vista Home Basic PC to the router. Most times I am unsuccessful.
Feb 19, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
How do I Enable Encryption or secure my wireless Network?
To enable encryption, you need to log into the router's configuration page: Click on Login -> Advanced Setup -> Wireless -> Encryption Think up a Hexadecimal code with the appropriate amount of characters for the level of encryption you wish to use (Hexadecimal means you can use any number between 0 and 9, and the letters A through F). 128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD EF 01 23 45 6D F9 64-bit encryption uses 10 characters. Example: 01 A3 45 F7 89
Feb 19, 2006 | SMC Barricade 7004 Router
SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG) Logo
80 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Kris
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
