I have a old destiny river hot tub. The lights stopped working suddenly. I can hear a click every time I'm pressing the lights button. That probably means that a relay is clicking so the panel button is working well. But my question is do LEDs are connected in parallel or series? If series if one LED fails all of them will not work (good luck to find the bad one). Anyone have an idea?
The button is stuck in? Which button? If it is the flasher button then I would think that is why the brake lights and the flashers don't work. If it is the button behind the brake pedal that is stuck in it should keep the brake lights on and that would stop the flashers from working. I need more clarification on which button you are talking about being stuck.
I suspect the start button. In many bikes the start button deactivates the headlight to provide full power for starting. This continuous load works the button mechanism quite hard.
Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
Open and close the lid of HP printer once. The light will start blinking.
Press the green button. Your HP toner cartridge chip will be reset.
I recently had this problem,it appears to be in the emergency flasher button.at first no brake lights but center one worked. the emergency button was stuck and hard to move but once i got it loose i had all brake lights, so thinking my problem was solved i checked all lights and then found i had no signal lights, i went bach to the flasher button because it was still very hard to move and pressed down further and all lights work now so i think this will cure most turn and brake signal problems. the flasher button is rarely used and collects dust so it starts to stick and when you dust your dash or bump the button it will stick between contacts and the lights stop working. hope this helps!!
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
