Replacement Brush Roller, Fits Hoover UH70400 Windtunnel Air Bagless ... A brush roller on your vacuum is really like a broom for your carpet, that gets all the ...
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
If this is new, you have a years warranty on it, take it for repair. Did you get the right belts, the numbers are 38528035 for the flat belt and 38528034 for the V belt. Also if you are catching something like a towel or area rug in the brush roll, it will knock of the belt. Is the brush roll turning freely. If not then it needs to be replaced, does it motor sound ok? If not then there is a problem with it.
You didn;'t say what the problem is, but I assume that the brush roll is not turning. Take of the cover over the brush roll, then you can get to the brush roll and the belt. The belt probably came off or broke. Best to replace the belt.
Check the inlet down by the brush roll to make sure it isn't clogged. If not and the hose isn't clogged, then probably the thermo protector (part #28382093) maybe bad. It is mounted near the motor. Could be motor Part #43576188. But I would suspect a clog in the inlet or hose, or the thermo protector has gone bad.
You didn't give your model #, but most Hoover's, if you turn the vac ove, take out the screws to remove the plate covering the brush roll and belt. The number of the belt is on the belt, unless it is worn off, it is also on the metal tag that the model number is on. Put belt around the motor shaft or pulley, then around the brush roll and stretch it to put brush roll in place. If this is a wind tunnel, it has 2 belts, one for brush roll, which is a V belt, and a flat belt for the motor to the pulley.
