SOURCE: My Galaxy Tab just hanged and the screen is off
Hello, attempt to perform a hard reset and see if the device responds at all.
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
the unit should work normally after the reset is complete.
SOURCE: My Samsung Galaxy Tab says
You're in download mode. If you're not connected to USB, then pull the battery and plug it back in. This will restart your device.
SOURCE: i need to download user manual for samsung galaxy
You can download the available documents from the following website.
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP01&searchWord=galaxytabpc&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=galaxy+tab+pc+
Please let me know if you require any further assistance.
Thanks
SOURCE: Hi, i have Galaxy Tab model
Install these drivers http://firon.net/xda/Samsung_Mobile_Driver_V1.3.800_For_SPH-d700_Epic_4G.zip for windows 32bit
this should fix your problem
