Intel D946GZIS Motherboard Logo
Posted on Feb 17, 2011
A bootable device has not been detected in Intel 945GNT motherboard
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6318
Points
Solving of problem of a bootable device has not been detected. Please refer to the product guide at http://support.intel.com/support/motherboards/desktop/
yaseen
Level 1:
New Friend:
  • Posted on Sep 11, 2014
yaseen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6318
Points
A bootable device has not been detected please refer to the product guide at intel mother board
3 Related Answers
Anonymous
  • 14 Answers
  • Posted on Mar 03, 2011
SOURCE: hai sir iam using in intel d945gcnl desktop is
If it displays a message saying "A bootable device has not been detected " Please check that the IDE Cable from the CD-ROM is connected Firmly to the IDE Header as displayed above and also check whether the ATA cable from the Hard Drive is connected to the Serial ATA Header Firmly.
"If you are using two optical drives be sure to check whether Primary Master and Slave are configured properly using the Jumper" If you are using one CD-ROM don't consider about this.
Forixx
Bebe Perez
  • 78 Answers
  • Posted on Mar 30, 2010
SOURCE: enable to boot bootable usb drive,ga-945gzm-s2 motherboard
reset your bios inside your pc its a big watch battery take it out for 10 15 min then put back it if that does not work take out the battery again and if you see neer your battery was ther should be a small jumper its usually black and its plugged in your board it also should have 3 pins to plug it in when you take it out plug it in the next 2 pins (the miffle one will plug in aswell then put it back in the first pins again put battery back in an try to boot it should work...
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Sep 18, 2010
SOURCE: I have replaced the motherboard
you need a NIC ethernet driver
2answers
Bootable device has not been dectected
When the PC cannot see a boot file/disk on either thehard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press anykey" First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk. If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case andre-seat the data cable on the hard drive and also where it connects to themotherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Bootable device is not detected
The hard disk has died, replace it and reinstall Windows.
2answers
Hai sir iam using in intel d945gcnl desktop is propleam (a bootable device has not been detected)wihch propleam in intel board
Do you have multiple hard drives in your system. In the BIOS select the first boot device and select the 2nd HDD as first boot device.
to get into the bios press del and then use cursor keys to highlight boot tab and then select first boot device as HDD. Use the hard drive boot priority menu to select appropriate HDD as first device to boot.This option is only valid if you have two or more hdd's else your OS is corrupt and you will have to reinstall windows. Even check if all the cables to your HDD are tight, you will have to open up the system , if the system was moved around the cables might have become loose and just have to pushed in well.
Problem is when computer loads it says a bootable device has not been detected please refer to the product guide
Really need more information. NON boot disk is usually related to the boot sector. what operating system? Linux. XP VISTA. what type of hard drive? what brand?
2answers
DEAR SIR, I AM USING INTEL 945GNT DESKTOP
shutdown is due to overheating there is a sensor inside every processor to protect it from overheating nd if the temperature goes above this temperature it automatically shutdown.
if you are using a desktop then change your cabinet buy a airy one with extra fan installed in it. or you can open one side of your cabinet to sink the heat quick;y.
22helpful
4answers
A bootable device has not been detected.
Please refer to the product guide.
Bootable device hav been not deacted
Go to the bios settings as the system starts up by pressing F2 key then change first boot device as HDD(harddisk) and second boot device as cd rom, then press save and exit (F10 KEY)
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
