Philips Magnavox 42MF521D/37 Television Logo
Posted on Jul 25, 2008
42 plasma tv model42mf230a/37 blue light on no picture no sound
Blue light on no picture no sound remote will not work battery change
  • 1 more comment
  • Anonymous Jul 27, 2008
    i have the same problem purchased the TV on Oct. 6 2006 from Home Depot, A few days ago it stopped working, Blue light on , no picture, no sound and out of warranty,
  • vielmetter Feb 12, 2009
    I have the same problem. I replaced the Ysustain board and still no picture. After a few seconds of being on it starts smelling very faintly and I immediately turn it off...i'm sure that's bad. I'm looking at replacing the power supply board next but really i think there's more broke on this tv (upper,lower buffers are prolly bad too). I'll keep you posted if i get anywhere with my repair.
  • Anonymous May 05, 2009
    Luckily mine was under the extended warranty, unfortunately after three visits and a month later the TV is still borke. He said he replaced the power supply board, does anyone know if the power supply board and the board with the external AV connections are the same.
Anonymous
Level 1:
  • Contributor 52 Answers
  • Posted on Aug 19, 2008
Anonymous
Contributor
Level 1:
Answers
52
Questions
0
Helped
22143
Points
83
With solid blue led set could be still powering on but would need to verify by checking power supply voltages. if up and signal is present with no menu or audio would be ssb as audio amplifier, micro processor and eeprom are on that board. if voltages are not present you need to offload x and y sustain boards one at a time from power supply and check voltages and if vs comes up with either board disconnected replace that board
  • Anonymous Aug 21, 2012
    Daniel, I know that ssb relates to a board but, which board are you refering to?
Hitachi TV turns on but cannot get channels.The blue light and power lite comes on. Changed batteries in remote, still no channels
sounds like a simple input problem, find the input button on the remote or the tv and change the source input until you get a picture,
Ch 9 picture froizen.has sound.cannot change
U have cable,some kind of pay tv?Tries unplug the cable box,replug the box for reset or to update new solfware for the box.If u have free air tv,get better antena like out side door antena or a digital antena.Also should change the batteries in ur remote and clean the IR lights both remote and tv make sure no blocking path to signal.
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
First time to operate indicater light comes on reacts to remote but no picture or sound 42 philips flat tv
First red light normal
Now select channel or other source from remote with full batteries or pushing buttons left down side of TV. Red light is only stand-by
Sound no picture
If you have the 3 RCA jack cables connected to the input jacks on the TV press input on the remote until the picture appears.
Intermitten remote sensor issue
Sounds like to me the comcast HDTV box is the issue if you are using that to change channels. Let me know.
1helpful
4answers
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
