How to Format a Hard Disk
After you create the partitions, you must format the partitions:
Restart your computer with the Startup disk in the floppy disk drive.
NOTE: If you are using a Windows 95 Startup disk, a command prompt is displayed and you can skip to step 2. If you are using a Windows 98, Windows 98 Second Edition, or Windows Me Startup disk, select the Start computer without CD-ROM support menu option when the Windows 98 Startup menu is displayed.
2. When a command prompt is displayed, type format c: /s and then press ENTER. This command transfers the system files and should only be used when you format drive C (or your "active" drive). For all other partitions, type format drive: (where drive is the letter of the partition that you want to format).
NOTE: If you receive a "Bad command" or "Bad file name" error message, you may need to extract the Format.com tool to your boot disk. To do this, type the following command at a command prompt, and then press ENTER:
Extract ebd.cab format.com
After the Format.com tool is extracted to your boot disk, type format c: /s t a command prompt to format your active partition, or type format drive: if you want to format a partition that is not your active partition.
3. When you successfully run the Format.com tool, you receive the following message:
WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with Format?
4. Press Y, and then press ENTER to format drive C.
5. After the format procedure is finished, you receive the following message:
Volume label (11 characters, ENTER for none)?
NOTE: This is an optional feature that you can use to type a name for the drive. You can either type an 11-character name for the drive, or you can leave it blank by pressing ENTER.
You don't mention XP or SATA. As the windows system has crashed and I can't therefore open I can't open ''my computer'' to see the drive to use the format command. For some reason when I use the startup disk and input the SATA driver info using F6 although it seems to except it the setup procedure fails. Due to this I want to make a clean XP installation but cannot find a way of formatting the two SATA drives.
Regards Terry Cole
