Miele Novotronic T230C Electric Dryer Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I disconnect the alarm when the drying is finished?
Anonymous
Level 3:
Guru:
  • Master 679 Answers
  • Posted on Feb 17, 2011
Anonymous
Master
Level 3:
Guru:
Answers
679
Questions
Helped
168750
Points
2165
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Add Your Answer
    Avanti DW18 Built-in Dishwasher how to bypass finish alarm
    The simplest solution is to locate the buzzer and disconnect it. There is an 8 second timer that could also be disconnected.
    Can the alarm buzzer that signals the drying is done be turned off?
    Sure, disconnect one of the wires going to it.
    Aug 30, 2017 • Dryers
    How do I turn on the alarm when the dryer is finished?
    Many dryers do not have an alarm. If the alarm worked when the dryer was new, the wire to the buzzer may be loose, or the buzzer itself may be burned out.
    1helpful
    Very dry and straight
    I have no idea where you are, but here are 2 things that might help. My wife always removed clothes that need to be dry and straight just before the dryer finishes drying them and either irons them or hangs on hangers to finish drying outside the dryer. I have known many people who also put clothes that need to be dry and straight under their mattresses to finish drying. Sleeping on them under the mattress is the same as ironing them. Be blessed.
    Jun 23, 2013 • Dryers
    I have a 1997 volkswagen jetta gl 2.0 and while i was driving suddenly my alarm goes off, so i shut off the car and go outside to unlock the doors and lock them to shut off the alarm but that doesnt work,...
    I have heard of VW's of this era having issues with water getting on the alarm module board, which causes the alarm to go off without rhyme or reason. I believe the seal around the water deflectors near the windshield cracks or degrades. The alarm module should be under the hood near the windshield on the driver's side, under a plastic cover. If you can locate it, you could try drying it off and seeing if that helps.
    An alternative is that the wiring in the door could be getting wet, if the seals are no longer good.
    If you just need to make it *******, remove the fuse for the horn, if you can find it.
    I want to disconnect the buzzer sound on my dryer
    First of all if you can remove the back of the console to expose the timer and switches, there is usually a small block with 2 wires to it, and it has no knob connected, this is usually the alarm buzzer, remove 1 wire and tape it off,then try the dryer if no alarm wala.
    2answers
    I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
    Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
    1helpful
    Maytag Neptune Dryer--Drying Problems
    clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
    Top Miele Dryers Experts
    Kolbrun...
    ADMIN Andrew
    ADMIN Andrew
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a Miele Dryer Expert? Answer questions, earn points and help others
