Whirlpool LSR8433K Top Load Washer Logo
Posted on Feb 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water just keeps flowing from the machine - Whirlpool LSR8433K Top Load Washer
Cool Blue Services
Level 3:
  • Master 560 Answers
  • Posted on Feb 18, 2011
Cool Blue Services
Master
Level 3:
Answers
560
Questions
0
Helped
225012
Points
1573
Replace the load size switch/diaphragm assembly.
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
My tank on my nouva simonilli Program machine keeps filling even with no power to the machine. I thought it might be the valve just after the pump (looks like it needs a certin pressure to open the valve...
There are 2 1/4 turn valves under the black safety cover under the drain tray, make sure the one closest to the inlet solenoid is turned off. If that is off and water still flows into the boiler then one of the exchangers might be damaged.
When machine is switched on with a full tank of water the display just keeps saying 'rinse machine' i have pressed the appro button several times but it just keeps doing the same thing. lots of...
The flow meter inside the machine has a little dirt in it. The machine is not sensing the rinse water flowing through the system because the flow meter is blocked.
Doctor coffee
3helpful
It keeps telling me "needs to prime" and I try to prime it and it doesn't work. No water comes out of the steam wand. I can tell that the machine is working, but I can't get anything to change on the...
Hi You have a flow meter that needs to be replaced. It has probably been plugged with a coffee chip (usual cause) when the water tank was off. If the flow meter is restricted water can't flow or flow fast enough to spin the flow meter and the machine won't work.
1helpful
The water keep flowing out when it is on. Why?
This is what we call a syphone effect //locate the drain hose at the back of the machine and lift it up it is more than likely laying too low to the ground the hose should come out the machine and up about half way to the top of the machine then into the drain out let set hose like this and you shpuld have no more free flow of water
1helpful
KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
1helpful
Water keeps running into my washing machine. Even
Water valve is stuck open, probably by lime or calcium build-up. Proper fix is to replace the water valve. How old is the washer?
We have recently bought a Maytag Epic front load washer and F & H keeps comming up...what's the problem?
FH is an indication the the machine is not sensing enough water flowing into the machine....
The only thing you can do without taking the machine apart is to disconnect the water hoses to the back of your machine and inspect the filter screens for any type of debris that might be restricting water flow into the machine. Typically, the cold water line is more susceptible to foreign matter than the hot waterline.
If screens appear OK then the problem may be with the water fill valve, water flow sensor, water pressure switch or blockage in the water pressure switch hose.
Cant adjust water flow
You need to replace the printed circuit card in the machine.
1helpful
Drum will not spin
If your water keeps flowing out, it could be that the pipe behind is not at the correct level, about three feet from ground level; your pump pumps the water out OVER this height. It should not be at ground level.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
