My dish network receiver is hooked up to input 1 on my sony bravia tv.
every time the tv is turned off, and turned back on, there is no picture. I can change to input 2 and sometimes it will come back on. This tv is only about a week old.
Hook up your Dish receiver to HDMI 1 port on your TV. Press the input button on your TV remote to change the input to HDMI 1 and you should get a picture on your TV.
which Dish Receiver do u have. if it is a Dual Tuner (322,625,622, 722) u run a RG6 Coax from the Dish to the back of the Receiver. on back of the receiver there should be two ports (Dish 1,, and Dish2) u will need two short pieces of coax and a Separator ,(which should have come with the Receiver. u hook the coax from the outside Dish to the single port of the Separator , now u run a coax (or RCA or what ever) to the TV. Turn on TV and Receiver.
on the Dish remote u hit the Menu button and hit #6 then #1 and #1 again (wait for each screen to change ) u should see a signal bar at the bottom. U will need to get someone to turn the dish a little at a time till u get a signal. once u get a strong signal u hit the Check Switch and let it program.
There are a few reasons that this could happen. The main reason would be that the tv is on the incorrect channel or input. You will want to make sure that if you are at TV1, the channel is on 3 or 4, and an input if needed, such as VIDEO 1 or 2. If at TV2, the channel needs to be on 60 or 73. Cabling is another reason this could be. You want to make sure that if you are at TV1, all cables going from the receiver to the TV are connected on the back of the receiver at the green TV1 location. For TV2, the cable needs to be connected to the HOME DISTRIBUTION output on the back of the receiver.
I assume you are connecting a Dish Network receiver (model?) to your Sony TV with an HDMI cable. I also assume this happens daily. At a certain time (default 3AM but changeable) the Dish receiver (modern models) will reboot and the "screensaver" it normally outputs will be turned off for a minute or so. Some TVs, in obeying the rules for high definition connection (HDCP) will unlink their connection. Some are fussier than others and some will not automatically recover on power up. Since the Dish receiver must reboot to maintain its stability and then refresh its guide, you should be able to do this if the TV is turned off overnight.
If you still cannot get the connection maintained, I recommend that you connect with component cables--RGB+RW cables (the red-Y, the green Y=luminance, and blue-Y signals and audio right and left.) You may have to select a different input before turning the TV off, or maybe just changing source input will recover the one you want. I have no problems with my VIP722 receiver and my Samsung DLP TV. You might be able to get some more specific advice from the www.AVSforum.com message board for you TV.
-Ken
If they never gave you a written disclaimer about equipment that is incompatible with their service then tell them that your contract is not valid and you will not pay them. Because of your specific issue you are not actually receiving the service that they are getting your money for. You're paying full price just for the signal to be sent to you. If they again refuse to cancel the service without penalty or alter it to be compatible with your TV then contact the Better Business Bureau and file a complaint. Any trouble beyond that let me know I'll connect you with my brother who is a lawyer.
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Since we know you are using a coax cable to connect the receiver toTV1, check the receiver's back panel for the output name. If your receiver hasa "TV CH 3/4 out":Tune TV to channel 3 or channel 4, if it is labeled "Home Distribution": TuneTV to channel 62 or 75. We also want to ensure that the TV and thereceiver are connected properly, please visit this link to for moreinformation: http://www.dishnetwork.com/SupportSection/setup-receiver-totv.Once we have made sure everything is connected properly, unplug receiver for 10seconds then plug it back in, this will reset the receiver. If we are still notgetting a picture connect another component (VCR, DVD Player, etc.) to the sameTV, using same cable, same input, and same channel to see if it works. If youget a picture with the other component give us a call at 1-800-333-DISH (3474)for some additional troubleshooting. If it doesn't work with the othercomponent then replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang DISH Network Customer Service Representative
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
