Kodak EasyShare M853 Digital Camera Logo
Posted on Jul 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
We recently purchased one of these cameras and after only a short time we're having a major problem with it. The inner lens has only partly retracted and is stuck and won't fully retract. The camera is not not useable because of this problem...keeps telling me there is a "lens error 122,1,0,0".
Through my own research I have found out this is a common fault with this model and would like to know what options Kodak offer with regards to fixing or replacing the camera?
Kind Regards
Margaret :) Lens is stuck and will not open or retract. When turned on I get the same
lens error 122,1,0,0. Please help.
  • Anonymous Sep 23, 2008
    mine was in my hand and i turned it on and the lens retracted but not the full way. I tunrned it on and it said lens error 122, 1, 0, 0 . The screen was black
Ekse
Level 3:
  • Kodak Master 13,435 Answers
  • Posted on Jul 25, 2008
Ekse
Kodak Master
Level 3:
Answers
13435
Questions
82
Helped
3983797
Points
38023
Best to send in for service.
free estimate
http://www.advancecamera.com/repair/
Ginko
Level 3:
  • Kodak Master 19,396 Answers
Ginko
Kodak Master
Level 3:
Answers
19396
Questions
25
Helped
8074948
Points
55462
Try helping the camera to retract using your fingers while you turn camera off, try also helping lens to full extent if they don't.if you do not succeed in this simple way the camera lens must be taken apart and reassembled at a repair shop.
3 Related Answers
targis55
Mike Bulpin
  • Posted on Jun 29, 2008
SOURCE: Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
My daughter's phone got slept on. Lens was not square and would not retract. After reading all the stories of woe I suspected it was alost cause. I pushed on the bigger piece of the lens till it clicked and it immediately closed up and worked no problem. If you still have warrantee let Kodak look after it, if not then brute force did work. Just push up in the direction it looks like it needs to go.
Anonymous
  • Posted on Mar 20, 2009
When I recieved this error message after dropping my camera, I took a thin bladed knife and gently went around the outer and inner lense until it caught. Normally the lense will stick because it is bent from the drop. If you are gentle you can bend it back without damaging the screen.
  • 102366 Answers
  • Posted on Feb 23, 2010
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Kodak M853. The lense will not retract, and the outer lense is crooked.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
2answers
Why does my kodak easyshare camera come on and go right off
Lens problem, bring it to service center for lens re allignment
2answers
You will be offered a repair or a service upgrade.
To check on your options, go to www.kodak.com/go/itg.
Lens Error 10e, 1,1,0
Well, the only time i received that message is when I was holding the lens down with a finger while turning it on.
1helpful
2answers
KODAK LENS ERROR 122 1 0 0
if your looking where it says lens error 122 then when you turn it on it will say it i have the same problem but worse
8answers
Lens error 122
ok,white screen is LCDproblum or flex conecting pro,error 122 is ur lens barrel stuckup or mechanical gears problum this is repareable u try ur local repairer
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
