I have an old valor homeflame fire could you tell me how tha logs are put in position please
    Brigadier General:
  • 4,736 Answers
Here's a link to the Valor website home page.http://www.valorfireplaces.com/
Click on the Downloads tab and you may find the Owners Manual for your gas fireplace. It will show you how to install and arrange the logs properly. If you can't find the model you have, on the manuals page, use their contact information and call them.
Hope this helps you.
Posted on Feb 18, 2011
6ya staff
SOURCE:
How do you change the bulb in the valor dream 843 electric fire
Hi Lyn
This isnt telling you much i am afraid, but i have put a link to the pdf user installer manual which has a phone number which i am sure if you call they will explain how to, if you cant get the link the number is 0844 8711 565 or if you are in Ireland its 0044 844 8711 565 http://www.gotogasdocs.co.uk/f/m/Valor/Fires/843%20Dream%20LED%20install%20and%20owner%20(5133695-01).pdf
Nov 23, 2014 | Valor Car Audio & Video
Initial problem was that fire was taking long time to light, no spark being generated intermittently. Now Gas fire seems to be going off on its own when it has been on for a while. Fire is the hole in the...
First, have you changed the battery in the ignition system? If you haven't this could be causing your ignition problem. In addition, the Thermocouple may need to be replaced to solve the problem of the burner flames going of on their own. That's assuming the pilot light is also going out when the burners go out. It would also be wise to check the vent pipe to make sure it's not obstructed in any way. As this also, could cause the flames to go out. Because there is a Safety Overload Switch, that automatically shuts the burner off is there is a gas and heat buildup/backup in the firebox.
As far as replacing the Thermocouple is concerned, this unit uses the same type of stand-alone Thermocouple, as the older DESA Vent-free gas log sets and fireplaces used. It's held in place with a saddle strap mounting and is fairly easy to replace.
These fireplaces are made in the UK and therefore, are more complicated to install, diagnose a problem and then solve it, than those made in the U.S.
Hope this has helped get you headed in the right direction.
Feb 25, 2011 | Heating & Cooling
Can I fit a Valor Homeflame Harmony gas fire with a class 2 flue?
Just for information ... whether you're doing it as a 'B' -Vent (Straight up) or a Direct Vent (Straight out the back), it requires an appropriately sized Coaxial Vent Pipe. A Coaxial Vent Pipe is a pipe within a pipe, That has an air space in between the inner and outer pipe. Of course it will also need the appropriate termination cover.
For for technical advice on proper venting go to http://www.valorfireplaces.com
Feb 08, 2011 | Heating & Cooling
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Put together starter system need a diagram on a valor tropic 121 wall gas fire
You should be able to download the installer instructions on
Valors website, the information can be found here
under Trade then installer guides
www.valor.co.uk
alternatively new Valor Gas Fires
Jan 02, 2011 | Valor Toys
The flame effect on my valor 846 electric fire is not coming on, i think it is an led that is not lighting up. how do you change the led and where can i get one. thanks Gerald
The LED is on a circuit board located inside the fire. The board itself needs to be replaced.
The part would be available from valor spares under your warranty.
The number for valor spares can be found at Valor fires
Dec 26, 2010 | Stoves Heating & Cooling
Bought valor homeflame super off a friend gas fitter won't fit until he gets istruction maual
google valor you should be able to get manual off there site you will need model number
May 02, 2010 | Heating & Cooling
I have a valor hone flame gas fire. It is quite old now and I believe the ignition switch is faulty. Does this fire have a self generating ingier or ir there a battery ?
I believe the valor is self generating. Ours is also not working and we need to replace it. Any ideas where to purchase one?
Feb 10, 2010 | Valor Toys
Heating & Cooling Logo
1,091 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
