Question about Symbol Spectrum24 AP 3020 (AP-3020-100-E1)
I am trying to connect an AP3020 from Symbol to our existing 100base network. But somehow this doesn't work. It should get an ip based on it's mac address (by DHCP) but it just doesn't show up. I am using a straight cable (like it says in the manual) to connect it to one of our switches. Any other device that I connect to this switch (on the same port) gets an ip without a problem. What could be wrong? (I have 2 of these accesspoint, but neither of them work)
    New Friend:
  • 22 Answers
RESET ROUTER DIAGNOSE THE PROBLEM.
Posted on Feb 18, 2011
Anonymous
SOURCE:
1518-A! router
Click Start on your computer then Run and type cmd then press Enter.
When the DOS command box opens then type ipconfig and press Enter The computer will the display the IP address that was issued to your computer BUT if the IP address is 0.0.0.0 then your router did not issue an IP address to your computer and you need to repair the network connection.
Oct 03, 2012 | Zhone 1518-A1-NA Wireless Broadband Router...
We have a Konica Minolta bizhub 250 All-In-One Laser Printer and somehow we disabled the network connection and now the printer doesn't allow any connection to it through the network cable even if
When the copier is on the network does the little leds flash at the network connection? ping the ip address of the copier what do you get.
Go into admin mode on the copier network setting what is your ip address, subnet and gateway reading did you replace a router? now the network is one system and the copier was never told this new info?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 01, 2018 | Konica Minolta bizhub 250 All-In-One Laser...
I cannot connect to my 3Com OfficeConnect Wireless (3crwps10075-us) Print Server 3crwps10075
Check you firewalls. Sometimes you will have to allow certain mac addresses or certain ip addresses (may be less secure than the mac address), then change sharing level to full, before things begin to work.
Please post back and let me know if this helps!
Feb 21, 2012 | 3Com OfficeConnect Wireless...
I recently got a Mac desktop and my Linksys router disk will not open up. Do I need a router that is made for Macs or is there a way to configure the Linksys?
Hi, You are correct. The CD is not compatible with Mac. What you have to do is Configuring the Router Manually using the Web Based Configuration panel.
How to:
  1. Open your Web Browser
  2. Type http://192.168.1.1 in the Address Bar and hit Enter
  3. If you have changed the address somehow you have to enter that (Router's IP - Default Gateway)
  4. Here is a small guide to Fine your routers IP address in case of that you are unable to access
  5. Enter the user name (default user name is blank- means no user name. Just leave it blank), Default password is admin.
  6. Now you can configure the Router using the Menus.
  7. Make sure that you have Saved your settings before Exit the Web Based Setup.
  8. Make sure that you have changed the Default Password.
  • If you can’t access the router’s web-based setup page, please check the following: cable connections, router’s LEDs, IP address, and connectivity.
  • Connecting Devices Together
  • Ensure that you have an Active Internet Connection and connect the modem to the router’s Internet port and the Mac to any of the four Ethernet ports.
  • Checking the Router’s LEDs
  • After connecting your modem and Mac to the router, check the lights on the front panel of the router.
  • Checking the Router’s IP Address
  • To find a Linksys router’s Local IP address, you have to check the IP settings of the Mac
  • Checking the Mac’s Connectivity with the Router
  • Ensure that the Mac is properly connected to the router.
You can download the Manuals from here to learn how to do Advanced, Customized Configurations.
Note: Please select the appropriate Hardware Version.
Thanks for contacting Fixya! Feel free to ask any questions if you face trouble with the setup. Please rate the answer as well!
Jun 22, 2010 | Linksys Wireless-G WRT54GS Router...
Mac ibook g4 connect to an existing wireless network?
Usual problems are making sure that you select the correct security options at both ends and then DHCP problems. I would disable DHCP on the mac and select your own IP address above the existing ones to start with
Oct 11, 2009 | D-Link DIR-625 (790069292637) Wireless...
Symbol MC9090 unable to connect to wireless network...
check in your router MAC security
if in your router MAC security is enabled then only those can connect whose MAC addresses are in allow list in router.
you can access your router with following link
http://192.168.1.1
or
http://192.168.1.0
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password
then go to wireless advanced security then check MAC security if enabled then add your moto MAC in allow list.
Let me know .
Jul 29, 2009 | Symbol Motorola MC9090 Mobile Computer
Limited or no connection!
http://www.snapfiles.com/get/winsockxpfix.html
Try running that program and if that does not fix your problem then you should goto your network connections page inside of the control panel and right clickon your Wireless Connection and go to properties, Once there click on Internet Protocol TCP/IP to highlight it and then click properties and make sure everyhting is set to obtain automatically.
Apr 07, 2009 | Acer Aspire One PC Notebook
Cant print in my network
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Feb 15, 2008 | HP Color LaserJet 2600n Printer
Wireless problem
Changing MAC address of a router is usally not nessicary and can cause this issue. ARP (Address Resoution Proticol) maps the IP addresses of ever device on the network to their MAC addresses. To make this process more efficent computers cache (store) this information for quicker retrival. So once your computer has connected to your router it stores it's MAC address. When it trys to connect again, and you've changed the MAC address the computer will still try to connect t a device with the old MAC address which now doesn't exist.
If you find it nessicary to change the MAC address of the router you'll want to clear the ARP cache on the machines that connect to it. To do so type "netsh interface ip delete arpcache" from a command line.
Feb 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Symbol Spectrum24 AP 3020 (AP-3020-100-E1) Logo
218 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
