Hi LOCKING/UNLOCKING THE VSI The VSI has a feature that enables you to lock your power chair to prevent unauthorized use. To lock the VSI: 1. With the VSI powered on, press and hold the on/off key. After one (1) second, the VSI should beep. 2. Release the on/off key. 3. Push the joystick to the full forward position until the VSI beeps. 4. Pull the joystick to the full rearward position until the VSI beeps. 5. Release the joystick. There should be a long beep. 6. The VSI is now locked. To unlock the VSI: 1. Press the on/off key and power on the VSI. The maximum speed/profile
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
indicator should ripple side to side.
Good Luck
mi mobility
One of the most common controllers, codes to help you and others.
VSI & VR2 Joystick error flash codes:
Check out this very informative site (were the above came from)
Hope this helps, If so please click the "Yes" button
Regards, Mark.
check it got this type of joystick, https://www.pridemobility.com/pdf/owners...
if not let me know...
