LG 42PQ30 42 in. Plasma TV Logo
Anonymous Posted on Feb 18, 2011
I have an lg 42pq30 plasma tv the main input board went bad causing no audio.. i replaced the board with same part number .. it now has sound but the picture at the right is off the screen good 20% of picture missing.. did reset under picture.. no help.. any help thanks.
Anonymous
Level 3:
President:
  • LG Master 1,779 Answers
  • Posted on Feb 18, 2011
Anonymous
LG Master
Level 3:
President:
Answers
1779
Questions
Helped
578734
Points
5452
You must use a usb memory stick to copy data values from the old board to the new board. First you have to put the old board back in, insert the stick then follow prompts to copy register values to the memory stick. Then put the new one back in and load the values back onto the new. I would definitely have a certified tech do this process. You don't want to make a mistake with the old board values.
Why No Video from Aux Inputs?
Sounds like it could be a bad connection. Is the socket good? Are the plugs going into it OK?
2helpful
2answers
What to do to fix?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
WHERE IS THE MAIN FUSE ON A LG PLASMA,42PQ30
You can locate it near the power cable that gets connected into the power supply board. But, please take care, as you are touching areas where power can still exist even if you unplug the TV.
LG 42PQ30 plasma tv wont turn on anymore, when you plug the tv in it makes a click noise and when you hit the power button the blue light comes on then changes to red after couple seconds. Note the...
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_19_09_pm.jpg
I have an lg 42pq30 the main input board lost sound so i replaced it with same part number.. got sound back but the video runs off the right side of screen...any help thanks in advance
you need the set up remote, part number 105-301-m . in start mode press tools button, rt click until your model shows up. the main board is for several size screens. HIT enter when you see your model number.
Please post feedback
I have a problem with my lg 42pq30 plasma, it has vertical lines distortion across the screen. does anyone know how to fix this problem
yes is the 2 top & botton board connect to Y board control is bad need new one
Most problem on plasma TV is heat & burner some component, about 80% is 2 top & bottom board connect to Y board is come in bad
Lg plasm flat panel tv 42pq30 one month old has vertical pink and green lines that roll from bottom to top any answers.
Your set should be under warranty. This could be a clocking circuit that is out of sync, or some other processing device that is out of frame sync. To service this at board level, if it is not a standard factory known fault to correct, or if it involves extensive SMD work, the board with the fault will be replaced.
Jerry G.
1helpful
Need owner's manual for LG 42
You can get the manual on link below. Go to support then look under documents on right side to download manual.
http://www.lge.com/us/tv-audio-video/televisions/LG-plasma-tv-42PQ30.jsp
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
