Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Feb 19, 2011
The washer shakes violently then the off balance sensor trips when a load is in the washer.
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Feb 19, 2011
Anonymous
Contributor
Level 1:
Answers
21
Questions
0
Helped
9145
Points
62
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
My Midea washer spins violently in spin cycle. Please help!
It sounds like there may be an issue with the balance of your washer. When a washer is out of balance, it can spin violently and cause the machine to reset. Here are a few things you can try:
  1. Make sure the washer is level: Use a spirit level to check if the washer is level. If it is not, adjust the legs until it is.
  2. Distribute the load evenly: Make sure the load inside the washer is distributed evenly. This will help to keep the washer balanced during the spin cycle.
  3. Check for foreign objects: Make sure there are no foreign objects in the drum or the drum's seal, which may cause the washer to vibrate.
  4. Check the suspension: Inspect the suspension system, which supports the drum and keeps it in balance. If the suspension is damaged or worn out, it will need to be replaced.
If the problem persists, it's best to contact the manufacturer or a professional technician for further assistance.
1helpful
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
During spindrying the WFT9230TP shakes violently although the feet are all pressing tightly against the floor.
The clothes must be balanced inside the drum in order to stop the violent shaking. Unlike a front loader, the top loaders must be balanced before starting the load.
If you need more assistance, let me know.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
5helpful
4answers
LG wm2277hw front load shakes violently
Barry The repairman was right. The drum is out of balance because of the load amount .Thed clothes or items need to be distributed around the drom rather than just throwing in. When it comes to spin the imbalance causes the machine to shake and move across the laudry.
As it sometimes works This is probably when you are not doing a heavy load of washing, so it appears to work OK.
Pack it with less, also adjust the front legs a full turn higher than the rear so prevent walking when it spins.If you cant find the spanner that was included , just use an adjustable one.
7helpful
3answers
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
2answers
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
1helpful
2answers
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
