Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
SOURCE: Konica Minolta DiMAGE Z6
I have used a 4GB card, but sometimes unable to read it direct from a card reader. This maybe my card reader limititions, but if i connected a USB cble to the camera, i could access pictures without a problem. Hope that helps.
SOURCE: The Konica Minolta DiMAGE Z6 will not read the 8
The Z6 uses MMC and SD cards. If you look carefully at your 8GB card, you'll see that it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The Z6 is limited to cards 2GB and smaller.
