SMARTKEY Password Recovery Bundle is a must-have toolkit to recover/remove/reset passwords for Windows, Excel, Word, Access, PowerPoint, Outlook, Outlook Express, PDF, RAR/WinRAR, ZIP/WinZIP, MSN, AOL, Google Talk, Paltalk, Trillian, Miranda, Opera, Firefox and IE Browser, etc. Over 21 types of passwords can be Recovered instantly. Until now, these password recovery tools are the fastest on the market, the easiest to use and the least expensive..
1. prepare cd Hirens Boot cd
2.do the settings in bios for boot sequence
3.insert hirens boot cd then restart the computer
4.the process wil begin booting from the cd , will appear the following :
5.select option no3"password and registry tools..." then press enter button
6.then select option no1" active password changer..."then press enter button
7.then select option no2" search for MS SAM database...."then press enter
8.select drive contain window that will be on admin password reset,usually by default is drive c,if the computer is more then one windows then navigate to the drive that contains windows which will be reset , then press enter button.
9.select a password that you will give way,for example Administrator if the message appears successful password reset,then restart your computer ,then booting normally then you r back to the normal windows,without admin password.
10.in the next dialog select the clear this user password ,if the message appears successful password reset,press esc button to return to dosout of hiren cd
11.then computer restarts ,then boot normally then windows are normal again, without admin password.
Dear Friend,
If you are referring to the Bios Password, removed the battery and push down the power button for about 30 to 60 seconds to reset it (this apply to major brands). If it does not work, you might have to open apart and removed the bios battery for about 5 seconds.
Now, if you are referring to the Windows Password, there are many software that can help you to achieved this (Google it). Normally, in Windows XP you press down the following key combination: Crtl + Alt and press the Del button twice (during log on screen) this will bring the Log on to Windows screen where Username can be try as Administrator with no password, allowing you to get inside and change your password.
Good Luck!!!
