SOURCE: Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
SOURCE: Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
SOURCE: GE side by side fridge not cooling, can't adjust temp control
Try unplugging it for a minute and then plug it back in.
SOURCE: ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
SOURCE: We own a RF267AARS/XXA refrigerator.
You'll have to read my in depth review on Epinions.com for answers. Sounds like you bought the updated version that over corrects the "too much" ice which jams the mechanism to where it breaks the unit. This is my second friggen Samsung as my 1st 4 door quatro was replaced under their lemon law. Spending $2500 I thought I was buying quaility, instead I bought greif. I'm still working with Best Buy to get Samsung to fix the icemaker with it's current problem which sounds like yours. Go to the Epinions website and look me up, my username is "walkerpkw" My review was posted last year. Read both my horrifying Samsung reviews. Something is very wrong with their engineering department. You'll find my email address on my profile page. I'd be happy to inform you if the get this fixed. I'm told it's the fridges computer board and they're redisigning another?
