Tag Heuer Kirium Formula 1 Chronograph Watch Logo
Posted on Feb 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need set the time and date - Tag Heuer Kirium Formula 1 Chronograph Watch
Anonymous
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on Feb 20, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
63
Questions
0
Helped
17705
Points
198
TO SET TIME AND DATE, PUSH SIDE BUTTONS TOGETHER OR AT SAME TIME TO MAKE THE SCREEN OR FACE OF WATCH APPEAR WITH ITS TIME OR DATE, THEN GO TO OTHER SIDE BUTTONS TO GO UP OR DOWN ON THE TIME OR DATE UNTIL YOU GET TO THE PROPER TIME AND DATE. THEN GO BACK TO FIRST BUTTONS YOU PUSHED AND PUSH THEM ONCE MORE TO GET OUT OF THE SETTING MODE.
1helpful
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
8helpful
I just got a Invicta Corduba watch and I need to set the time. How do I do that? The number on the back is #6675. Thanks
this watch has a screw down crown. lift up the protector bar or start to unscrew down until it pops out, then turn slowly and pul gently all way out. set the time . tere is 2 positions there. full out time and inbetwwen them is the date and day settings.when there turn up or down until date chages, if it has day and date , up is day down is date.you have to turn few times for it to move..set the date ,set day before and go around . the 12 see number change to might date, set the correct time am or pm. push the crown in and screw in up til hand tight.
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
4helpful
Instructions for Armitron All Sport 40/6623 time setting needed.
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
I need to change the date on my watch and don't have the instruction manual. Thanks!
mcdevito75 here, Sounds like you have the time set, but the date is a fifferent matter, Here"s what to do, the stem (winder) of your watch has 2 positions, slip a fingernail just under the stem, and gently lift the stem to it;'s first position, this position allows you to change the date without so many cycles of the entire watch, it"s a little tricky but you"ll get used to it. Once you get this first position set the date to 1 day before the date you want, now pull the stem out to set the time of day, go thru 1, 24 hour cycle to set the date you want and time of day. The date is now set and will change on time, approx. Mid nite. Hope this helps.
Aug 03, 2010 • Watches
Tozai digital watch-setting correct time/date
I need to correct the time/date setting on a tozai digital watch.
Apr 05, 2009 • Watches
7helpful
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 • Watches
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
20helpful
4answers
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 • Watches
4answers
Setting the time
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Top Tag Heuer Watches Experts
k24674
Sean Wright
Sean Wright
Ngoro
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
