Maytag Dependable Clean Top MAV5920EWW Top Load Washer Logo
Posted on Feb 20, 2011
I have a brand new Maytag Bravos MCT top loaded washer. It makes a squeaky noise when agitator is cleaning. The squeak is getting louder and I've probably only used the washer a dozen times. We checked to see if the machine was level and it is. Any ideas?
Anonymous
Level 1:
  • Contributor 29 Answers
  • Posted on Feb 20, 2011
Anonymous
Contributor
Level 1:
Answers
29
Questions
Helped
8758
Points
81
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
My 2016 Maytag bravos XL MCT showing error code F5. Is this a simple fix?
Lid lock error. They are explained here:
https://www.searspartsdirect.com/washer-repair/error-codes/maytag-bravos-mvw-top-load-washer-error-codes.html
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Is there a reset on a may tag bravos mct washer
Top 565 Complaints and Reviews about Maytag Bravos
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.2 - ‎241 votes This Maytag Bravos HE machine has the poorest design! ... So disappointed in Maytag - I have a 2013 Bravos washing machine that if I had it repaired again (less .... Called Maytag because my owner's manual stated I had a 10 yr warranty.
3helpful
2answers
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
1helpful
MAV-3 top load washer makes loud squeaky noise during the wash cycle.
Is it a constant squeak or does it go squeak-squeak - squeak as it agitates? It is a squeak that is intermittant then usually your brake is losing its hold. You will need a technician to do this job. It requires special tools that they should have. I repeat a technician should do this job. You can seriously hurt yourself attempting this repair. Also see if the inner tup is turning as it agitates, if it is then it i definately the brake. But one more time do not try this repair it is a dangerous repair that should be left to technicians. There is a spring that is under heavy compression that requires a tool to release it.
3helpful
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
1helpful
3answers
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
