Master
- Posted on Feb 21, 2011
Re: When turned on battery indicator lights flash rather...
The flashes are indicating a problem with the chair. Count the number of flashes and that will tell you the error code and what the problem is ie 4 flashes pause 4 flashes indicate a right motor problem. your users manual should have the error codes in it to explain what each is Hope this helps
