You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Crushed ice is the default position and the solenoid is energized to cube ice.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Testimonial: "Wow! Thanks for the instant answer. I'll take it apart and see where the problem is. Does the rotation direction change to make crushed versus cubed?"
